1.66 60' (down 2/10 on my best of 1.46!)
Last best time was 9.66 @ 148.95 on the 1.46 60'
Now best is 9.508 @ 153.03 which just took the Aust title
Keir's record was 9.510 @ 152 on a 1.50 60'
Loved running that V8 Torana down on the last run, was all over the track & nearly crossed the centre line in 5th & hit him! If I had backed off he would have beat me, so I kept on it,fought the steering wheel & got him by a bumper bar over the line.He had at least a car length on me with 50m to go & would have been suprised that I caught him! 9.849 @ 138.63
On the 153 mph run I was in 6th gear & kept it buried well past the speed traps - & it pulled up well(who says I need a parachute)
  • Replies 88
Tell the good people what RPM you were pulling on the 9.508 run , John!!!
And about the drama's you went through to even get the thing back on the track for that run. Like I said to you on the night, things are sent to test people's endevour, you stuck at it and reaped the rewards.
I did get the final 9.849 run on video, you can see a bit of a tango from the car.
Damn fool didnt bother setting up the video for the important run though!!
/trying to kick self in the head.
Well done to MattR on your first outing... knocked 0.7 off his first run!
Andrew with the snakies in the burnout pad!!! lmao
I didnt see Whatsisname run. Bugger
I saw Kier's one run, 9.9something, but heard noises halfway down the track, they think its a valve spring problem.
Trust me mate, you didn't miss much.
Sorry about the edit in your post above! I had a slight moderator technical difficulty - I f@#ked up.
I sent a very long-winded email to [email protected] (I hope that's the right address) this afternoon about the whole debacle. After my spiel I wouldn't be surprised if they gave the whole of SAUSA a free ticket :D I complained on behalf of everybody .... but I still think everyone should send in their own opinions - what happened is just not on, in my opinion. Especially for guys like Matt (Whatshisname)! I consider myself fortunate to have had 3 runs in light of other's misforutunes!
    • What blows me away, is watching some of the US guys, like Tony Angelo at Stay Tuned. LS1, buys a set of heads for $1200, drops a mild cam in, pulls all the electrics, drops a basic inlet manifold with a carb, MSD thing for spark, and roll it out to make 550hp.
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
