Option1Garage in QLD sell them, they're to suit S13 Silvias but they went straight into my R31 so I guess they will probably fit R32/33/34 as well. I think all modern Nissans are the same (I think).
They're 70mm long as opposed to the standard 50mm, and are made by NICE products.
ARP make them as well I think, they'd probably be pretty strong as well being ARP.
Edited by Bluprint
A company called NiceProducts makes replacement / longer wheel studs. You can buy them from Repco or (Autobarn if you want to pay more). Below i have the part numbers for front and rear because on r33's they are different.
Front - NS1450
Rear - NS4500
also some pics to show the dimensions
Edited by arh32
Front - NS1450
Rear - NS4500
After talking to Nice Products they have confirmed for me that the correct part numbers for an R33 skyline are:
http://www.niceproducts.com.au
Front NS4530
Rear NS4570
I am rechecking these to be sure they are correct pitch and so forth....
Stud & Nut = $9 each (F-ing steep..!) I am asking if they will sell stud only as I have some nice nut wwhich were extremely hard to find, the studs are 72-75mm long....
Is it ok for me to cut these down you reckon?
Edited by 75coupe
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
