How many Stagea owners does it take...
306 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Sorry if this has been covered but nice to have an update, be interesting to see how many of Stageas have representation on here.
Nice idea Cruise, 97 RS Four V, Auto, stock mech so far.
18" rims with dish, full body kit, twin sunnies, Jap AV head unit (what am I going to do with that?)
Cheers
Luke
P.S. Don't forget to add yourself to the Stagea World Map thanks to Ska
Stagea World Map!
Edited by munchdesign
https://www.sau.com.au/forums/topic/119090-stagea-owners/
  • Replies 292
Posted Images
good work luke :D
maybe we should post what model we have as well
mines a 96 series 1 rs four converted to full gtr running gear (rb26 engine, gtr manual gearbox, gtr diff, r34 brembo brakes, etc)
slightly modified as well ;)
heres a little piccy i took a while back
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2194235
98' RS4, silver. Tinted front door glass. Earthed boost sol. CES split dump/ front pipe,3" cat and back exhaust with no rear muffler. K+N panel filter. S/S vented coilpack cover. Baby seat for Ella. D/C tranny oil cooler. Waiting for Rad. air deflector. Have fitted SAF-C. Need to fit boost gage, Adj. cam gear, R32gtst w/gate act., atmo. bov and get tuned. Bought Alexcims F+R Whiteline swaybars, yet to fit.
Edited by skidkid
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2194890
96 RS Four V. Silver with body coloured bumpers
Factory: Leather interior, dual sunroof, bodykit.
Mods: FMIC, Pod + CAI, 3" turbo back exhaust, full TEIN coilovers + Whiteline swaybars + adjustable camber arms, tow bar, 18" wheels, boost controller, turbo timer, Bosch 044. 260RS spoiler, eyelids, aftermarket grill
In my garage/in the mail: PowerFC, Hiflo GCG turbo, R33 GTR 5spd + conversion kit
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2195138
2000 S2 Mellow Yellow RS2
3' split dump and full exhaust system, K&N Panel filter.
Highflowed stock turbo - home job on the lathe.
Jaycar DFA, IEBC, Fan cooled IC, Viper VX791,
oh, and 3 baby seats.
It's also slow but I still won the Motorkhana on the skidpan against a bunch of R33/34's and a Soarer.
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2195498
98 series 2 Silver Tipronic
Arrives next week....finally!
Has full M'sFactory bodykit with 260RS wing, KYB suspension, rear sturt brace
Mods waiting in garage to go on once complied
Masa R34 GTR front end, Either R34 GTR 18x9 wheels or Volk GTC 18x8, have not decided yet
R33 GTR manual conversion, S/S split dump and cat, need to find a cat back
R34 GTT front and rear brakes, adj castor rods and rear camber arms
Factory manual centre gauges, S/S Stagea kick plates
Front mount intercooler kit and Bosch fuel pump
Blitz SBC IDiii and nismo clear front and side indicators
Still to get
Turbo, Poncams, Power FC, injectors, coilovers, seats, ganador mirrors, towbar
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2196040
1997 S1 RSfour 25det auto
light green
earthed solenoid
sic pod filter just cos it sounds nice
18x8.5s
nismo front bar
s-tune decals
indy girl skirt hanging from rearview mirror
shitty xplod head unit
260W pioneer 3way in each door, 2x 800W pioneer monoblock amps, 2x 100W 12in pioneer subs.
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2197663
post-26133-1153792636.jpgpost-26133-1153792666.jpgpost-26133-1153792689.jpgpost-26133-1153792748.jpgpost-26133-1153792798.jpgyellow 98 rs four s, koni adjustable suspenders, tinted out all round, mp3 head unit, r34 rims powdercoated black metal flake, turbosmart e-boost2 control unit, pivot speed meter, custom exhaust and dump pipe in stainless steel, adjustable camber and traction arms in rear, heavy duty adjustable selby swaybars front and rear,eyelids for the headlights, looking at haltech ems,and hoping my radiator deflector plate arrives soon, then i will be looking at fitting a liquid to air intercooler.and trying to get some xenons so can burn the road a bit better Edited by oxford1327
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2198433
Dayz special edition series 1 Stagea RS V Four,
86000kms, automatic, RB25DET engine, Attessa 4wd
1997 model silky snow pearl, lives in southern Adelaide :(
Clarion stereo tape unit with 6-stack cd player
Clarion amp
Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Black Widow 10000 car alarm
New Oxygen sensor
New 400amp battery
Davies Craig automatic transmission oil cooler upgrade kit
Whiteline front and rear adjustable swaybars
Whiteline front castor kit
Whiteline rear subframe alignment kit
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system
3inch Catco high flow catalytic converter
3inch Dayz edition(?) cat-back exhaust system with quiet muffler
K&N pod filter
Cold Air Induction setup using standard snorkel air feed
Hybrid dual stage Electronic Boost Controller, set to 10 & 12psi
Apexi 'hybrid' front mount intercooler with custom pipe kit
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
R34 GTT 17inch rims
Hankook K104 tyres, 235/45/17
160 all wheel KW @ 12psi
eventually want 200awkw at 1bar, means hiflow turbo, injectors and larger front brakes!
https://www.sau.com.au/forums/topic/119090-stagea-owners/#findComment-2228444
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
