How many Stagea owners does it take...
306 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
finally got the pictures out of my knackered digicam and have posted them on page one of my 4wheel toy.
wanna know how you guys get your avatar pic so clear? cos whenever i put one in there by the time it gets reduced down enough to fit it looks real ordinary?
<---- see left for example
Edited by oxford1327
  • Replies 292
Posted Images
cheers guys i have been tryin to work out how to do it and it is frustrating the crap out of me cos on the screen it looks great until i save it to my avatar and the it goes all spakko on me
Hiya guys!
Just bought a S1 Stagea RS4 and decided it was time to join SAu.
Its silver 97 model and stock as rock. For the moment.
First mod will be a stereo that works, rims, and a DIN triple guage cluster.
Then later a cat back exhaust, hi-flow cat and FMIC.
Looking forward to being part of the 'community'
How the hell do I post a pic here...?
Hiya guys!
upload it onto a picture hosting site like photobucket.com or just upload it when u send a reply on sau by adding a file attatchment (scroll down on the reply message screen to see it)
Ok my Stagea has had some travel.
I've just removed an old 2004 rego sticker from Tasmania :eek:
The car then went to Kambalda, near Kalgoorlie WA, then to SA and now back home to Perth :dry:
TAS, WA, SA, WA that is impressive!!! How many owners in Aus I wonder?
I'm guessing 4, short lived in SA, the guy hadn't even reg'd it in SA, it was still on WA plates. He bought it in April, sold in July.. ODO reading is 71000, I have already done close to 3k lol (drove it across :(
Edited by StageaGirl
I'm guessing 4, short lived in SA, the guy hadn't even reg'd it in SA, it was still on WA plates. He bought it in April, sold in July.. ODO reading is 71000, I have already done close to 3k lol (drove it across :happy:
StageaGirl I thought I recognised your car I am dead sure that it used to belong to a tasmanian member of the Stagea section with the user name of Burkey22. The car was resprayed in TAS I believe unfortuantely the post where he put up a pic of the paint job is there but the pic is gone due to some gallery issues on the board. But the car was black with white rims and was in Tassie awfully big coincidence. Good for you though if you search his user name you can find out about your car.
here is the thread about the paint
http://www.skylinesaustralia.com/forums/in...c=57503&hl=
feel free to hit me if I am wrong
Seems to me like the word about stageas is getting out in Perth if we go for a cruise it will be Huge
I count 9 people currently active dont know what happened to some others but there is way more on the road than 9 thats for sure
Brad (Cruiseliner)
Wildcat
MrGTST
RedSkyII
Myself (Glenn/McNamg)
StageaGirl
StageA
SHIFTdown
RadiuM
Thanks mcnam, It sounds like my car :)
Only problem with the paint work is that if a stone chips the paint, its down to metal :happy:
I'm going to research and see what else he did to the car ;)
Edited to add: Seems Burkey got a job in Kambalda (I use to live there)with the same company my father use to work for!! Small world!!
Have sent him a PM, but not sure if his email is still alive :mad:
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
