just a question on lag
mods=87mm arias pistons,eagle rods,,mild port polished head,ti springs and collars.to suit 256/ 8.5 poncams,greddy plenum.80mmthrotle body,9:1comp, flat decked block,manifold made of 1.5 inch od stainless tubing bellmouthed,knife edged crank
please some idea on what sort of revs a to4z would kick in with this kind of set up
Edited by spirosky33
https://www.sau.com.au/forums/topic/119098-hks-to4z-on-rb25/
I take it you have not searched yeah?
The answer is probably the same as the other threads about this :D
So i've searched for you
http://www.skylinesaustralia.com/forums/in...=118339&hl=t04z
http://www.skylinesaustralia.com/forums/in...opic=104554&hl=
cheers
should see that power with 75 hp bottle,otherwise 40 psi boost on a 35 40. otherwise i dont think so.
well im now leaning towards 450-500rwhp wich would be covered by the 3240 im guessing, car will be a weekender with a fair bit of track/strip use
Edited by Bezerkly
IMO 450rwhp is around as much as you would go on the RB25 otherwise its all just undue lag and wasted response.
Afterall its RWD still
If you want to track/circuit it... get something that will net 450rwhp as a peak. Otherwise your going to have allllll top end and nothing in the middle and the bottom.
A car better sorted suspension/brakes wise and 350rwhp will flog a$$ over something that has 450rwhp and nothing in the other departments
thanks for the response nismoid some food for thought there....brake ans suspension mods have been taken care of engines built and awaitin and running motec m800atm just trying to save for all the bolt on goods....thanks again for your opinion
