Dear all,
Picture my rear lights looking like this:
OO OO
12 34
Half of the 2nd light (number 2) from the left is not lighting up.
Is it a simple bulb change? or is there something more to it?
If it is just the bulb, what kind of bulb should I be getting?
I would pull it out to check but I am not at home at the momment.
Thanks
https://www.sau.com.au/forums/topic/119115-r34-gtt-rear-round-lights/
Okay this problem happened to my r34 shortly after picking it up from the importer at exactly the same semi circle as yours nuffsaid.
Although it may look tricky to replace the bulbs you have to detach the whole tailight. You can do this by using a small wrench to loosen and remove 5 nuts that hold the tailight. You can see it after removing the carpet-like material the surrounds your boot. If they're a bit tight spray some wd-40. As for the bulb Im not sure what model it's but it is a universal model and can be bought at a service station.
Ongsta, perhaps it could be with the voltage/amp rating of the bulbs you used?
I was wondering if the tail lights in the R34 have to be rewired a bit when they are complied for australia. Cos i noticed when changing a bulb in mine that the wires had been cut and spliced in to other wires just using a bit of sticky tape to hold them. Has anyone else noticed this, or had it done?
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
