New precedent set in Court yesterday
Federal Court Ruling from the Melbourne Age , Australia (AP) -
A seven year old boy was at the centre of a courtroom drama yesterday when he challenged a court ruling over who should have custody of him.
The boy has a history of being beaten by his parents and the judge initially awarded custody to his aunt, in keeping with the child custody law and regulations requiring that family unity be maintained to the degree possible.
The boy surprised the court when he proclaimed that his aunt beat him more than his parents and he adamantly refused to live with her. When the judge suggested that he live with his grandparents, the boy cried out that they also beat him.
After considering the remainder of the immediate family and learning that domestic violence was apparently a way of life among them, the judge took the unprecedented step of allowing the boy to propose who should have custody of him.
After two recesses to check legal references and confer with child welfare officials, the judge granted temporary custody to the Queensland state of origin team, whom the boy firmly believes are not capable of beating anyone.
free bump :dry:
There was me and 1 other supporting QLD in the first game at the Jerra Pub. Wouldn't mind a few more SAU'ers and maybe QLD can win and I get bragging rights for a few weeks.
Or maybe QLD loose and I get dumped on again.
Either way its always social at the Jerra.
you bastard!!! :thumbsup: nice work though.....
im still going to jerra tomorrow night guys, so i hope many of you will be there. save me a seat, i might be late, but i should be there before kick off. i have other commitments before hand, but hopefully all should be good.....
see ya there!
BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES! BLUES!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
