Hi, Guys !
I'm new here, so don't give me hard time due to my first post :D.
Studying in China, Beijing right now. And had this stupid idea bugging my head for a couple of months.
They have a31 here (Rb20de and rb24e carby). There are all LHD.
So I've been thinking if I get one a31 and get all the gt-r running gear into the car. I know with the right money everything's possible, but has anyone done it before ?
I've seen jz, rb26 powered a31, but I'm deffinetly sure there were no 4wd ones.
I've heard that the RB26 front cv joints won't be able to reach the hubs, due to different suspension geometry etc.
Can some one please clear those things up for me, so I won't have any stupid ideas anymore ? lol
Thanks in advance!
https://www.sau.com.au/forums/topic/119120-rb26-atessa-a31-possible/
Cefiros came out with atessa out of the factory, rare as but yuup, came out from factory with rb20det's
they were the Nissan Cefiro SE-4
chassis code ELNA31.
so if you found one of these theres no reason you wouldnt be able 2 bolt up an rb26 to it. :D
Edited by KICKIN
Importing one is a huge problem. And RHDs are banned here ? Stupid laws. For stupid people :D
So if I will have to do the work by myself. What should I really look into ? Swap the whole GTR suspension ? It's like building one from scrap lol :ermm:
im not able to find much info on it as its a rare mofo but heres a link.
hope you speak multiple languages...
hehe.
cefiro links
http://www.auto.vl.ru/catalog/nissan/cefiro/1992_5/
And a link from our very own meggala (steve)
http://www.meggala.com/1cefiro/cefiropage.html
Edited by KICKIN
I have one of these elna31's :) its currently running a gtr32 g/b as they came as 100% factory auto i was thinkin of doing the rb26 attessa thing with it but im just gonna drop the whole lot out and make it rb25 rwd :)
ANd they also have the exact same double wishbone setup as the 32's not the og s13 style
wanna buy it :)
Edited by etbenno
  • 1 month later...
Sorry for diggin up and old post, and sorry if it seems a silly question...
But......do the A31 Ceffys, in RWD guise, use the same strut front end (or simmilar to) an S13? And the AWD use the same as an R32? Or do all Ceffys use the same R32 wishbone style suspension?
AWD ceffys have a different chassis to the RWD ones (just like GTS4's have the same chassis as GTR's and not GTSt's), so their suspension geometry is also accordingly different
Hmmmmm.........
Interesting....as the S13 front suspension fits into an R31......And I have been toying with the thought of an AWD r31 using the A31 AWD gear....that was assuming the AWD front end was like the S13 front end may have made my job easier.
Well....Not much has happened....I have a 26 powered R31 and have been thinking of doing the AWD for some time now.
Realisitcally I am doing as much background working out as I can before I do anything.
a group in the US is putting an RB26DETT and AWD drivetrain into an S14, so if you put your mind to it, and have the $$$ to back it up, then it should be possible.
But yeah, converting a RWD cef to AWD is a bit of a waste of time, when you can already buy AWD ceffy chassis from factory. There's heaps of em in the snowy/mountain areas of japan.
As for AWD R31... hmmm nice idea, but isn't the Nissan Langley 4WD GT pretty much the same?
yeah true... its more like a AWD bluebird than an R31. Very cool idea. Bit of a beyotch to do, you'd have to fabricate new chassis rails to accomodate front axles etc.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
