i have a r32 half cut with no engine but lots of nick naks
theres no engine in it but the speedo cluster is there radiator ($50) and everything under the dash (sorry no switches) steering rack, power steering pump, air con condenser, aircon pump, pedals (manual pedals!!!!! great for a manual conversion) dash looms
SMS or phone me on 0410 800 678
https://www.sau.com.au/forums/topic/119144-fs-bris-parts-from-a-r32-half-cut/
sorry as per usual when you buy a half cut it has no panels (well it has one but its dented)
there myst be someone with a heater core thats broken or climate controll that doesnt work? or some one that needs a power steering pump
  • 1 month later...
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
