Hey All,
Well, the time has come to FINALLY get a 3" exhaust + dump pipe for the 32 GTS-t. I'm not after stainless steal, just as long as the tip is stainless.
Iv been around to a few places, and theres been a bit of difference in prices, ranging from about $1200 to $1600.
The cheapest one sounds alright, but the dump pipe has got 2 75 degree angles in it. The most expensive looks far straighter, and actually sits higher than the stock exhaust.
Anyway, am I going to get much better performance out of the most expensive system? Or does it just seem like a bit waste of money?
Thanks
Ash
https://www.sau.com.au/forums/topic/119173-different-exhausts-prices/
generally speaking you get what you pay for if its a straighter exaust that sits better than stock were the cheaper has 75deg bends in it? well theres your money rite there in flow properties alone
and the systems siting higher than stock well
i know what id be getting
the price of the exhaust doesn't really have much in common with bends. a lot of cheap exhausts have a more straight flow design. better exhausts will have better sound reducing properties. like one of the apexi or hks ones, or whoever does it, which comes with a built in sound motor. it is an electronic device with a flap in it that can be turned from horizontal to vertical. at horizontal it lets through maximum air flow and noise, as you turn it vertical it reduces airflow, and causes more back pressure which causes more sound to be soaked up by the mufflers. my mate has a full jasma system and it is really quiet, i have a full x-force system and it is loud cause the jasma system has 2 sharp bends just before the rear muffler to quieten it down, whereas mine is more of a straight through system.
Edited by mad082
where the hell you going for your exhaust pricing? OMG $1600 and its not even stainless steel.. wtf?
ebay yourself a X-Force turbo back.. stainless steel, should be all under $1000... too easy
If your in sydney area... drop into Liverpool Exhausts on Seaton rd in Moorebank and they can show you dyno proof of their R33 GTST split-dump, Hi-Flow CAT and 3" Cat back set up... and their price as well as workmanship are EXCELLENT! i can vouch for them... Ask for Jimmy and tell him Sarkis with the silver R33 sent you.. you will get few $$$ discount...
Cheers
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
