18' Volk Racing and 17' AVS Model 6 wheel [ Post #1 ]
I have a 18 x 9 inch Volk Racing F zero Challenge suits R33 GTR and 17 x 9 inch AVS Model 6 suits R32 GTR (because R33 GTR has bigger brakes) both are white and very good condition. Asking for $3700 for Volks racing wheel and $2000 for AVS wheel.
The volk racing wheel is ultra light, a very nice wheel only i have to sell it to pay some bill.
pic up shortly
Thanks for that, Jimbo. It is indeed a very nice set of wheel, i think it is even lighter than many of 17 inch wheel. and yes it is the one with blue inner. If i got more money to pay off my car, i wouldn't want to sell it
  • 4 weeks later...
I am not sure yet whether the 18x9 would fit R33 GTS T yet, haven't really try it. because my car has GTR body panels so it fit GTR wheels. I will try with my friend's GTST, then I will tell you whether it fit or not
  • 3 weeks later...
  • 9 months later...
Originally posted by JiMb0
Once again, I'm running 18x9's .... on a gts-t ...... :confused:
Jimbo just because you've got 18x9's on your gts-t doesn't mean these will fit a gts-t
These mags would have GTR offset and your mags would have a offset to suit a gts-t which means more then likely these Volk's would stick outside the gaurds
guys... heh... we jumped from the 20th of the 8th 2002 through to the 30th of the 5th 2003.... i doubt he has the wheels or even checks these forums, seeing as his last post was from last august.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
