Signs Of A Faulty Tps? (throttle Position Sensor)
Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send. -
Yeah I spent close to a year finding one. I was even tempted to buy a RB25DE N/A head and port it out. That latter option, could still be an option. -
My head recently blew up on the dyno, been trying to find a replacement for the last 3 months with no luck. Does anyone know where I might be able to find one? Willing to chase down any leads at this point Cheers
