hi guys, i was wondering if upgrading my fuel pump, make any changes to the way my standard r32 drive .?
i know i might be able to find an answer to this, but when i search the word fuel or pump nearly every post comes up itll take for ever.
if someone could be kind enough to just let me know. my fuel pump is on its last legs, i dont know if i should change it with a better one or just replace it with a stock one.
cheers!
https://www.sau.com.au/forums/topic/119245-fuel-pumps/
If it's on its way out and you aren't planning on modding where it needs more fuel (i.e. running more boost, upgrading turbo, injectors etc) then you won't need a bigger one. Just replace with a stocker.
On the other hand if you're going to upgrade other things that require more fuel later then get a nismo/walbro/whatever brand you like.
https://www.sau.com.au/forums/topic/119245-fuel-pumps/#findComment-2197058
if you go for an intank pump there are plenty of options walbro are cheap and i have had good experiences with them also bosch 040 and 044 are good pumps. i wouldn't bother with another stock one i dont know many people who haven't modded their car. as to what it will do to driving the car providing the pump is installed properly it wont affect the car
https://www.sau.com.au/forums/topic/119245-fuel-pumps/#findComment-2197558
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
