hiya im in the process of modifying a r31 wagon and have come to a halt... i need my engine wired up to the car... its a rb25det neo manual out of a r34... the car was previously manual if that means anything... does anybody know of any good auto sparkies in sydney... someone that knows skylines back to front would be nice
thanks all
p.s. if its a friend of someones i will be able to pay cash if thats wat they want
https://www.sau.com.au/forums/topic/119249-good-auto-sparky-in-sydney/
i am using a standard computer (manual) i have the old r31 loom but has been pulled out with the engine... the motor i bought has the original uncut loom there is about three or four plugs that go through the firewall that dont have a home... one of em would go to the trip computer im guessing and maybe one of the other plugs would go to other options in the r34 maybe cruise control that button that baffles the exhaust or sumthing... the loom has been pulled through to the firewall and the old computer and relay has been pulled out... is there anything alse i can do to prepare the electrical myself without chopping and soldering wires???
thanks all for helping
Am I right to assume that you have the standard R34 ECU? If so, wouldn't the new Motor Loom plug straight into the ECU? Is this where your problem is...
Or is it that you have too many plugs from the new loom and you don't know where they go?
Please give me a better description of the dilemma, in-house sparky is on the case :)
Please give me a better description of the dilemma, in-house sparky is on the case :cheers:
yeh thats correct i have a standard r34 ecu... the one that came out of the car... all i need to do is hook up power to the computer... and to my ignition... and maybe the instruments... thats all i can think of that needs wiring up if i could get a electrical drawing of the ecu out of a r34 i could do it myself and i would know what wires go where... but id rather get someone who knows what they're doing...
yes i do have a few plugs without homes but i also have a few plugs from the r31 that dont match up to anything so im assuming one would be speedo ect and the other would be ignition... thats why i need someone who knows what they are doing like urself...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
