Hi guys,
I will be swapping my R32's cooked transfer case for a fresh one within the fortnight. I have not come across much information on SAU in relation to swapping the transfer case.
Can anyone who has done so offer any advice/tips on doing so?
Are there any parts that need to be replaced? eg washers, o-rings or anything alike?
From what I am aware of at present to get the gearbox out I have to remove and install the following:
1. Speedometer cable
2. Front propeller shaft
3. Clutch slave cylinder
4. Starter motor
5. Gear stick
6. Reverse lights plug
7. Exhaust (from the front pipe or from the dumps?)
8. E-TS hydraulic air bleeder actuator
9. Gearbox obviously
Removing the transfer case from the gearbox?
Edited by Remix-
  • 1 month later...
I don't have all the details but it was pretty straightforward once the box is out
The hardest part was the shifter, there is a rod from the transfer case where the shifter goes down to the gearbox it was fidly. The transfer case is just bolted on from memory, not sure if there was a gasket.
All the details would be in the workshop manual
Cheers for the response Duncan.
As I am attempting this in the driveway (backyard love :)) I would like to attempt to remove and replace the transfer case without taking the gearbox out (heavy bastard), eg I would prefer remove gearbox x-member/prop shaft and tailshaft to tilt the motor/box backwards towards the firewall thus giving me access to the top of the transfer case.
Has anyone attempted this with success?
I'm pretty sure you won't be able to do it, all the fiddly stuff is on top of the transfer case, even if you get your hand up there chances are you will drop the pin or rod into the box :P easier to take it off I reckon.
Would be interested to hear the trick if someone knows one :)
I've taken the transfer case off my busted gear box. Definately possible only with gearbox out of car.
Once you see the bolt and roll pins you have to remove in top of transfer case opening you will see what I mean. 1/2 hour job to pull apart with basic tools.
Box has to come down, no gasket, just use gearbox gasket goo. It's a good idea to change the selector shaft seal. Like others said its fairly straight forward when the box is on the ground. Pull the top cover off and knock the rollpin out enough so you can release the selector shaft.
Its a bitch to R+R the box off the car on the floor though much easier with a hoist and a tranny jack.
Drain the oil ouf of both before removing and dont forget to bleed the attessa.
You dont have to remove the dumps ( just as well they would be impossible to remove on the car), just the front pipes.
I just had my car up on the hoist and it appears my transmission fluid is leaking out of my transfer case somewhere. The mechanic couldn't pin point it exactly as obviously it sprays everywhere when driving but it appeared to be leaking out of where the front driveshaft connects and even possibly at a hydraulic hose at the rear of the transfer case.
Hopefully the box doesn't have to come out for this.
  • 4 months later...
Hey dude, just wondering if you know the part number for the selector shaft seal?
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
