Hi,
It seems I found the problem with my HICAS... My car can do more than 180kph and that leads me to believe that the speed sensor wire has been cut. I managed to work out where the ECU is (thanks to the forum), and managed to work out how to remove the footwell (thanks to a mirror and torch).
I couldn't see any wire cut at the base of the ECU, nor any wires cut on the way into the wiring trunk.. This leads me to believe that it's cut elsewhere.
Will having this wire cut affect the car in any way (except for HICAS playing up and no speed limiter)? Just want to make sure it's worth the effort trying to get the dash off to look in the back of the speedo...
https://www.sau.com.au/forums/topic/11928-ecu-speed-wire-cut/
Guest RedLineGTR
there also is a wire directly near the hicas system with a speed wire, i couldnt tell you where but there is one on the ecu which is not the main one, which you may have problems if both are not cut, unless the main one near the hicas system which is the one that actaully measures the speed it will not work properly which is the case with yours.
Dr Drift - Here's the crux of that problem... I cannot for the life of me get the ECU out. I exposed it, took off the wiring cap (with much difficulty) but I could not get the ECU's bracket off the bolts it's mounted on. To describe further (stop me when I go wrong) there are 2 nuts and one screw that needs to be removed. The screw is down the bottom, and the nuts are up the top, and right up the back. I could move the top of the ECU's bracket off the bolt that it sits on, and the bottom of the ECU came free when I removed the screw that held it in, but I just can't get the back of the bracket off the bolt that it sits on.. It won't move foward, back, left or right. So tight...
Am I inviting trouble if I try to remove the ECU's cover while it's still bolted in place? I can then get in there with works digi-cam and get a couple of happy snaps.
Oh, and if I do somehow manage to remove the ECU bracket from the frame of the car, what's the best way of unplugging the wiring loom? Does the battery need to be disconnected, or just have the car off?
what speed have u taken ur car to? there are some differences between actual speed and what ur car shows on the speedo...for example ive taken my car past 180 on the speedo and it appears to cut out at approx 190km/h but in actual fact becuase of the calibration of things it is actually 180km/h....... if you've taken you car to eg: 230km/h fair enough but if eg: u've taken it to say 190. id say its just the difference in readings...
Nah, stock steering wheel. Something's a little weird 'cause Hicas will move my rear wheels while the car is stationary (not much more than a twitch though). No speed alert chime, and no speed limiter. Oh well, if it's not going to blow up my engine or anything, I'm not going to worry about it too much.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
