Is there a problem with having boost in the chamber and no fuel? is it the same effect as leaning out or is it safe, as most aftermarket computers seem to use this function.
Just wondering, as my car can spend a bit of time bouncing on the rev limiter and my EMS only has a fuel cut function.
Apparently yes fuel cut can cause leaning out whilst banging the limiter. My theory is that as you're basically switching on and off the injectors whilst the engine is still breathing all the air in. So for example some piston intake cycles may not get the right amount of fuel it needs as the injector might only be active half way thru the intake cycle. Kinda hard to explain my theory. Ignition cut IMO is alot better.
Edited by Busky2k
Turning the fuel totally off to a cylinder doesn’t not cause lean running in that cylinder. No fuel = no combustion, therefore there is no running for it to be lean. Remember we are talking maximum rpm here. In the unlikely event that there is any fuel left over from one cycle, it will be consumed in the nest cycle. One cycle of combustion of a miniscule amount of fuel will not damage anything.
:D cheers :(
Edited by Sydneykid
Nah what I mean SK is if the fuel injector is switched off 3/4 the way through an intake cycle.. then... its lean for that cycle!
One cycle is not going to do anything.
Think about it, you snap off the throttle every gearchange.
The injector duty cycle goes to zero while you change gear
Until you get back on the throttle
What's the difference?
:rofl: cheers :ban:
Edited by Sydneykid
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
