Does anyone know where i can buy r33 stealth(drift) wings from. The only places I've found so far are Unique Autosports Just Jap and autoworx. All places are yet to advise me on availability. Any info would be hugely apreciated thanks.
Edited by gtst1976
https://www.sau.com.au/forums/topic/119289-r33-stealthdrift-wing/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
