I posted some pics of my DR30 the day i sold it, didn't get it out much when i had it, so most of my mates in these forums would'nt have seen it like this :P
there are a few snaps of my GTR too :)
http://www.skylinesaustralia.com/forums/in...7entry2198437
How much did you sell your DR30 for?
Let it go for 10k, the guy didn't beat me down once, and is happy as could be, ive been told many times its worth more :( i still regret selling it at all. To be honest i think the DR30 was a better can than my gtr, not as fast or powerfull but its just straight up tough! :D and the GTR has 2530's, PowerFC, 100mm Cooler, injectors, 4" zaust, etc etc quite a responsive and powerfull package, but i miss the DR :)
That photo of the engine bay was not as it was when i sold it, i pulled that motor setup out before selling it. I sold it with a pretty tight FJ, haltech, VG30 and a few other engine perfomance bits. The photo of the engine i posted was how i first built the car, fully restored engine bay etc, ran up just over 500kms in a brand new chris miltons engine, made 200rwkws at 9psi, running the engine in :D I still have that engine in the photo and everything to go with it, im trying to decide what to put it in... if i found another DR shell i would use that :)
But yeh, would have nailed a std GTR with a rolling start :)
Roll on it would have to be close to the GTR wouldn't it?
What power was it making?
And I never got to go for a ride in it. :D
Don't feel so bad i never got to go in it either...I did how ever see it reversing next to me whilst i was doing 60 odd after someone had a whoopsie in it hahahahahaha ;)
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
