Hi all,
Just recently ive decided to take advantage of the 98 octane 10% ethanol blend of fuel and can't say that ive had too much success. Just wondering if anyone else out there is in favour or against this type of fuel. I have noticed that although my car (R33) runs smoother and the fuel is currently seller for alot cheaper (1.30 per leter in adelaide) my car stalled as i was rounding a corner and if scared the crap out of me.....the stearing got really heavy (power assisted stearing failed) and i had to really struggle to keep the car on the straight and narrow. No damage done, but just wondering if anyone out there has had simular occurances since running an ethanol blend of fuel.
I went the the following web site when looking into ethanol fuel and as the article states under the "Will Ethanol damage my vehicle or affect its performance?, and i quote "If very Ethanol rich fuel is used this may cause an engine to stall. Which may be what has happened with my incident.
Website = http://www.raa.net/page.asp?TerID=146
Anyways just wondering if anyone else has had a situation like this. Also which brand of high octane fuel are people using out there, eg shell, caltex, mobile etc.
Kind Regards Evan
https://www.sau.com.au/forums/topic/119309-high-octane-fuel/
I have run 2 full tanks of "Boost 98" (50+ litre fills so old fuel dilutution will be about 97%) and I will not be using it any more.
This is in a 89 VR4 Galant so Skyline experience may be different...
The car does not start as well cold and if the engine is hot and you try starting after about 10-30 minutes it takes several seconds of cranking and when it does fire it will not idle, just dies. You have to give the engine a rev to about 2000rpm for it to settle to a stable idle.
Economy is noticably poorer too. 400km before filing up and I get 450km on Ultimate or Optimax.
My final word?
Leave the ethanol in beer where it belongs, not in your fuel!
Used that Optimax Extreme 100 Octane with 5% ethanol a few times after the 3rd tankful, it caused my car to jerk while driving and the check engine light to come on for some reason.
Went back to BP Ultimate, never saw these problems again.
Thanks for the info guys....i think its a matter of "what you pay for is what you get".....
Ethanol may be cheaper and better for the environment ( as has been stated in the opening post link) but it doesnt, as far as i can gather, make the car run smoother or more economically.
All the best guys and girls,
Regards Evan
For some months we have been running 5 X Skylines (1 X R32GTST, 2 X R33GTST’s, 2 X R32GTR’s) and 1 X Stagea on Optimax Extreme 100 ron and can only report good things. More power, better response, less knock, cleaner plugs in all cases and similar fuel economy in most cases. Slight improvements in economy have occurred occasionally, but never any worse economy. They have varying amounts of modifications, from a simple boost up, intercooler, SAFC tune for 165 rwkw in the Stagea to a full on 450 rwkw in the R32GTST.
Thus far I have only tuned one of them specifically to run on 100 ron, the R32GTST. Plus one of the R33GTST’s now satisfactorily runs the default Power FC ignition mapping, which it wouldn’t do before due to noticeable knock.
:D cheers :(
Ran the VR4 down until the fuel light came on and filled up with Ultimate so there could only be abour 1/2 a litre of ethanol left in there...
Starting problem fixed...
From now on I drink the ethanol courtesy of the Bundy Bear and my car gets straight petrol.
Ethanol is an Oxygenator so ideally you need to tune your car to get the full benfits of it.
As it burns it creates oxygen (good thing) thus allowing you to add more fuel to create more power. Generally your AF Ratio will will be leaner by about 1 whole point.
ie if your AF ratio is 12.5:1 on normal 98 and you then run E98 your AF Ratio will lean out to about 13.5:1 so you need to enrichen it to make up for the oxygen created during the combustion process. E98 when tuned correctly will also allow about 3 or 4 degrees of further advanced timing so it is definately a good thing in performance engines but will produce the results when tuned on it.
Street Commodores made an extra 30 KW at the wheels on a Tuned Clubsport by using ethanol based premium. The car was already making 230KW at the wheels using LS1 edit software and breathing mods then run on E98 and retuned the Fuel mixtures and ignition advance for a healthy gain.
I delivered 200 liters of E85 (85%ethanol 15% PULP) to a business in Sydney the other day to convert there drag car to run on it. Currently runs 8s on Methanol.....
  • 4 months later...
Does everyone know what ETHANOL really is???????
Us old timers have been using ethanol as a fuel improver for years, a Shell garage that used to be on the corner of King Georges Rd & Princes Hwy at Blakehurst used to pump it out of the ground at the bowser, and a BP service station on corner of Terry St & King Georges Rd used to pump it as well.
Sydneykid should remember these 2 places.
The difference is, in our younger days they called it different names, Shell was Methyl Benzine, BP was Benzol, Ampol was Toluol, but bottom line is, it's all the same stuff as the new wonder drug for cars, ETHANOL.
If your car is tuned to run on it, it can only be better in every way. The problem I guess with most of our EFI cars today, without some tricking up, the factory ECU's can't recognise the difference and hence the problems.
As a youngen, I used to get in Sydney a super (leaded for the juveniles) grade fuel that was often 105 ron octane. It was marketed by Boral under the name FLEETWING 100 and it really is a pity we can't get anything like it these days, unless buying specialised performance fuels.
Cheers, D
^^ erm, not the same thing. Ethanol is C2H6O and Methyl Benzene (Toluene) is C7H8.
Toluene increases octane but has no oxygen component. It's also a denser hydrocarbon than Ethanol.
Brazil certainly is running on 85% Ethanol, and good on them. It's more sustainable than pumping dino juice out of the ground.
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
