help with plate
S4TEEN - I like or 200SXY but i wouldnt be surprised if thats already taken and if it hasnt it should be :( But i think you would be mroe likely to put that on a chicks car.
Hey if you look in some car mags - you can steal ideas off the eastern staters plates. I opened up a car mag one day saw my NIZMO plates sitting there on a 200SX - spewin copycat! haha but then thought to myself if your actually looking for somethin sweeet to put on a number plate wouldnt be bad place to start getting ideas.
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-210900
Originally posted by adam 32
i saw an R33 today with plates
extr33m. now i know this is 1 persons opinion but why would you bother with personalised plates? i just think this attracts unneccessary attention to your car.
I got mine for the shows dude, i used to like my gov plates because ion order for them to fit i had to bend the sides so if a camera ever flashed they could hardly see the last number. Now though with the new plates ( SLY 33 ) if i get flash i get a fine which is fair enough.
IN the shows EVERYONE has private plates and i really liked the one I have i thought it kinda suits the car... low and sleek so i though of sly. I was never much for private plates but i do like them even though as you said it does draw unwanted attention, just have to be extra careful where i drive and park from now on. :P
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-212596
each to their own, and if you want private plates then go for it. but i kow of a few guys with them and they hate them - purely because of the attention it gets. whether it be in a carpark or drunken idiots. a skyline with a private plate is going to stick out more an attract the 'undesirables'
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-212610
Originally posted by MODADDIE
thanks everyone i think i am going to go with   "S4TEEN"   plate..
i will decide tomorrow at work when i finish filling out the form, i called licensing today and its still available...
anyone feel free to use "4PLNCHXS"
Ahh feel free to make fun of me.... I am usually pretty good with plates but I cant work out what the hell 4PLNCHXS is meant to mean??? Maybe its too early in the morning or something??? :P
https://www.sau.com.au/forums/topic/11932-help-with-plate/#findComment-213876
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
