mike ive pmed u about a deal we can make
i only need the Left side one and we can split it 75$ each
as you only need the right side one..
pls give me a call
0415 075 113
i need to sort this out ASAP thanks!
Edited by dongypro
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
