yeh it should pull pretty good :)
i only brought the stocko engine onto boost twice! i drove it back from newcastle off boost the whole way caus the clutch was stuffed that bad, then after putting the clutch in i smacked it side on into a gutter bending the left rear control arm, then the sat i got that fixed the engine let go
going to leave the stock turbos on for awhile and see what power i can get out of them, then i'll go the gtrs's ;)
get N1 turbo's they pull pretty hard i hear.
nah they'd be too small, id change the turbos now but i want to see what i can get out of the stockos with the 3ltr bottom end, plus the stock turbos r new, but when ive had enough of them im putting on the gtrs's, should be good for 700awhp
yeah they are a gun turbo. they spin like all buggery!
holy crap, how expensive are these..... http://cgi.ebay.com.au/CATCO-3-CAT-CONVERT...1QQcmdZViewItem
That is a very good price for what you are getting!!
Have a look around and make sure you check the flow rates as these are pretty much the best around. I think they usually go for around the $540 mark.
fair point
i picked up my new bottom end today :)
will be pulling out the 26 tomorrow and pull the head off to see what actually let go in it. then the 26 head and 30 bottom end are off to JHH next saturday to be built (fingers crossed nothing goes wrong)
if all goes to plan itll be back on the road in 3 weeks time, making some big numbers :)
He is THE man. Like when people talk about the man, its him.
Go next door to Johns, and see Daniel, talk to him about what turbos, he'll then put you on to Mike Vine. No doubt Daniel will tell you about this skyline they did a while ago, he is scared of that car. He is fine with the old jett racing RVR (which had that old datto ute motor in it) so yeah. Crazy car. Just talk to him hey.
farken turbos didnt want to come off did they, spent like 4 hours trying to get them off but nooo and i ended up running out of daylight too
all i've got left is to undo the drive shafts, then undo the engine/gearbox mounts and lift her out!
ill say this, damn the intercooler set-up is bloody weird! the way the bov's are run i mean, its like they designed the cooler and forgot about the bov's, and just whacked them in where ever they could
but i reckon i did pretty well seeing as i was the only one doing it, and i started at 9 plus it being the first time i've done something like this
cheers daveo...thinking about the turbos today, i think i might change them before the engine goes back in, caus i dont see how the hell u get them off whilst the engine is in the car..i even contemplated the idea of going a big single, even less of a pain in the ass lol
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
