He's not a Collector's Plate Set.
Nah that stuff is priceless, which Dave is also.
Timeless is like a peice of Chipindale furniture, old, well built, good wood, and even today still stylish!
*ps I am the suck up master :D *
LoL. Did he ask why you needed a twin plate?
Lol yeh I was going to add that but thought not. I was previously going to use a jap twin plate, but seeing as jim can build me a big single for half the price (and it still be streetable) I know what I’ll be using :D
Apparently the millennium motorsport supra and the subzero soarer use a big single clutch. So obviously a twin plate isn’t required.
Here's some sexywear for ya Dave...
Photochop anyone? :D
Thank you Anna, you have captured my essence wonderfully.
Not happy with the hair, but it will have to do for now.
And is it just me or does his package appear larger in the purple???
Yeah, he said mine should handel 800+bhp, its only a 5 puck single... Quite streetable a lot better than before. As I said tho, he would probably be modifying it, if you think you are getting jiped call him back and tell him about your findings and ask why his is so much more. Just have 30mins free.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
