Morning Whores of Spam-town...just doesn't have the same ring does it? :laugh:
*2nd try*
Morning Whores of Whoretown...thats better :wave:
This is noooo whoretown this is deadtown! i say all of you move to nsw!
ooh noes :wave: why dont you do it every year?? u know you get money from the govt .. how many times does that happen?
I have to pay the government ><
Really? i thought that was vitamin d lol..
if youre a scientist can i borrow your white lab coat.. haha..
I have a lab coat you can have
I drew Mr Hankey on it in nikko when I was bored in Chem lab but
Used to be there before moving up here *sigh*
I do miss teh excitement
Bah i just want to be able to get away from work and just laze found the beach :wave:
I dont want a mr hanky on it :laugh:
Beggars cant be choosers
And what now are you to cool for Mr Hankey??
You king of the forrest???
This YOUR SPECIAL BUSH?????
I have a Lab Coat but it isn't White, i cant even bleach it white.......
Dam Chemistry classes... so boring... lets see what happends when you pour stuff on your lab coat...... and what happens when you dry it over the bunsen burner............
i'm Bored!!!
I want Spam!!
Where's the Spam!!!
Subtle
Pornographic
Adult
Messages
Super
Powerful
All-Purpose
Medicines
:wave:
I am spam.. how would you like your green eggs and ham?
:laugh:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
