im back...
I went for a drive to north pine dam...
I went the extra extra long way... Boy o boy that dam is so dry... I mean its got so little water in it... The water is like 30 metres from the tree line now.
god gaskets are bloody expensive. picked a whole heap off dan last nite that i got him to order for me, came to $360. that was all inlet gaskets (plenum, throttle boddy) exhaust manifold, turbo gaskets, dump gaskets, and new cam top and bottom cover bolts and washers, & rear main oil seal.
Dont ya just wish there werent soo many little things that added up to alot, itd make evreything alot cheaper *sigh*
im back...
what are the roads like col? newly surfaced? nice and twisty? nice country side? thinking bout that for the MSC :(
Don't talk about the stickers! They are being looked at!
Shall we do the Coro for lunch this week? They have the coolest toilets :blush:
u mean teh regatta?
what sau needs is a skyline cruise through murwillumbah, down into NSW, across to Byron, and back..
That would be a great run.
ohhhh son of rajab i thought the day would never come when someone put forward that idea!!! but i think that one may be a little bit risky, i mean if EVERYONE on the cruise was responsible it would be ok, but u do get the odd couple...
Maybe not for the MSC but for another separate cruise?
I drove this when i brought the gtr back from newcastle, no-one on the road at 1am, twas a lovely drive :blush:
what are the roads like col? newly surfaced? nice and twisty? nice country side? thinking bout that for the MSC :blush:
u mean teh regatta?
Ummm roads were a bit so so...
I got some great photos from the top of clear mountain. I think that north pine dam is a great spot, however there are quite a number of families that like that dam on weekends also. There are heaps of BBQ's and loads of space for footy and cricket.
I will have a chat to Mud at the AGM (where ever the next general meeting is anyway) about the location and possibility of this location being used as its super close and great for bbq. Also we can go the long way like i did this morning which is a bit mountainous and fun to drive...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
