hey wat? wats up with urs now?
Well there is a fully built engine being offered for a low price...I could buy it and sell mine as a working unit (It works fine but I am a nervous person) and enjoy a relative ly low change over cost...bang all worries gone
u know theres no way in hell u'd get ur old engine out and the new one in intime for autosalon lol...if ur keen on the engine, and it's a real gem of one too, put it of until after autosalon maybe
I cant really put it off till after autosalon....as I have wakefiled soon after!
But I am assured the swap can be done in a day, for the cost of a steak BBQ lunch :wave:
want to share the details of the motor andy? u know we all like details :)
I forget alot of the details
But I remember
JE pistons
Eagle rods
Cryoed crank
N1 oil and water pumps
ACL race bearings
Some tricky head studs
The engine was built by a mate and was in a car that got written off 2000km after it was built so no run in period required :(
But I remember
JE pistons
Eagle rods
Cryoed crank
ACL race bearings
Does anna know about this? lol...sounds like its a bargain, i'd get it, therefore u dont need to worry about it going pop for a long time.
RE the N1 oil pump, i read this earlier today, http://www.skylinesaustralia.com/forums/in...howtopic=136134 and it's scared me a little bit. Im now thinking of replacing the oil pump for a JUN (or the likes) before the big turbo's go on :)
RE the N1 oil pump, i read this earlier today, http://www.skylinesaustralia.com/forums/in...howtopic=136134 and it's scared me a little bit. Im now thinking of replacing the oil pump for a JUN (or the likes) before the big turbo's go on :(
yeah I read that too, but I wont be too worried I will still only be making my current power..well maybe a smidge more after it is tuned with no air leaks lol
Yep Anna knows!
How much does a normal slightly tired rb25 go for these days?
with all that forged goodness u'd be silly not to run more boost :(
i'd just be having a rough guess, but it'd have to be $2500+? no idea really lol
Hmmm well that is good...that makes the changeover cost rather small :wave:
And yeah I will up the boost to the turbos max efficiency...wich is about 7psi more than I run now
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
