hrmm intersting, mite have to weigh up the options when it comes out.
speed limited to dial-up speeds, no excess charges on downloads
Same as mine! After 20G it's slowed to dial up :S
I like having a net connection here where the speed actually maxes out my NIC's top speed :P LONG LIVE THE AARNet!!!
OMG HI CY :(
Yeah I call it the Shat :D
:D
direct 4mb telstra connections is the fux0r!!!
hehe
Is that all? I have hit ~5MB/sec from USQ, not on a small file either, they go too fast to see speeds, so have to pick big arse dvd iso's :P
Gidday Andy and Anna :D how's mai fav ford single spinner watchers going? :P
SINGLE SHPINNERZ FO LIFE y0!11
Good good. Just finalising some work yep yep i'm actually doing work. Real work. There are enough people here to warrant having 3 secretaries, so I get to type stuffs... mmmmm... cheese and bacon balls.
we got 3links here.
1x 512 isdn backup
1x 2mb backup
1x 4mb operation link.
the 4mb link is shared between everyone here.
however, i allocated all bandwidth (80%) to VOIP and when not being fully utilised, its all allocated to me.
we got 3links here.
1x 512 isdn backup
1x 2mb backup
Nice, man this is hillarious!
http://video.google.com/videoplay?docid=-8161891871101469419
You wouldnt happen to have a spare S1 R33 ignitor would you :P This whole swapping the good one between cars is getting annoying lol
nope sorry i dont, maybe u can 'find' one at autosalon this weekend :D
See what I used to do? please use this link now as I'll have ot edit it out as THIS TYPE OF BEHAVIOUR IS NOT ACCEPTABLE BY SAU MEMBERS!!
EDIT: Link Removed, to protect the greater good :P
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
