OK, rice it is :)
if the engine needs a rebuild, i'll do it, not a problem. i'll talk to dan about this but from previous discussions, the rb25det engine can pretty much handle up to 300kw's without a rebuild but thats not constantly running a large amount of psi all the time.
lately, i just been runnin stock boost (turnin the avc-r to 'off' mode) and whenever needed or wanted, i just flick it over to map A or B.
Some times they can handle 300rwkw, but the consensus these days is that it is really closer to 280rwkw, An engine that is old and has had a history of making power at high boost it is probably even less or in any case will not last for any length of time at that power, I would start planning the rebuild now as it can take a while!
or u can cheat by buying a pre-built one and do the swap in a day, hey andy :)
gtr is gone. sold it.
why would u do something like that? :rofl:
How is everyone today?
good mate, been out most the morning at millennium msports, got no work :rofl:
how bout u?
I would love to tell Shanef what I am doing today but he gets all upset when he heres about the good life too much.....
Oh, but I did pick up all my travel documents for the next two weeks!!
its fine dave, i've come to grips with the fact that all old people do the same stuff that you do :)
I held very little back over the weekend. I think the bass affected my judgement and lowered my inhibitions just a tad...... As evidenced by the groin thrust dance and the swear count on Majorsick!! I needed to take more photos of T-shirts as I saw some absolute pearlers at AS!! Have ordered more but these aren't too rude......
Ahahaha it was great. Swear count was good, I love having majorsick around, he takes the focus of me swearing :whistling:
OMG this place is pure gold today, I haven't rofl'd so hard in a long time. What a joke. Thanks for making my day :sorcerer:
or u can cheat by buying a pre-built one and do the swap in a day, hey andy :whistling:
why would u do something like that? :woot:
good mate, been out most the morning at millennium msports, got no work :devil:
how bout u?
Not everyone has sweet pedros cousins style hook ups like me but Shane
good mate, been out most the morning at millennium msports, got no work :D
how bout u?
Yeah i am good, jealous that all of you got to go to BAS on the weekend i was 1400 k's away.
But not next year
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
