It is poxy... in comparison to the 32 :D
I can tell :laugh: ahahahaha I'm just bored is all :D
The temp is talking to herself again. This time about sneezing and saying 'bless you'. But she's saying it to herself! "Julie, I know when you sneeze you say bless you, ooh bless you Julie, thank you very much now I know this piece of cake should really be eaten but I just don't know *sneezes* oh bless you Julie..." :D
And the other chick in my section is pissed! She had a long lunch and came back off her guts. So she's sitting here watching youtube pissing herself laughing.
That's why i want a 32 they just have that look about them!
I dont thrash either, and if I had to pick one it wouldnt be the R32 because it hasnt been healthy enough to thrash since July
yes, but it is being tuned on Monday, isn't it, so hopefully they can work out some kinks!
OMG have any of you read that Tampon Ad thread in the wasteland? Well too bad if you haven't i'm posting my bit in here. This website is the cutest ever! http://www.moxie.com.au/ sif you wouldn't want to buy their products with fab packaging like that!
You can keep our poxy 33
okay :D
Bingo
I was once told that Tien was the sony explode of the suspension world! Over Hyped but actaully pretty crap...and they had shock dyno evidence to back it up! But I cant say cause I have never owned any!
hard as a f**k, no rebound, and dont have camber tops. (had them on the 33 also :laugh:)
It better be fixed or I wont be happy!
Woot for hitman tune
and woot for engine going BANG caus u went dodgey on the radiator :D
we're going to 10 pubs around brissy...happening 2nd december
:D
:laugh:
I will be soon, i only wanted to know if i would be in the area or still up here. Spoil sport :D
when are you going to be here?
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
