Geesss thats no good...
So did the other car take off i take it???
yes at the time when all this happen.... but later on after i got the car to a car park he came back and gave me all his details...
courtney is the owner so im pretty sure she can fill you in...
P.S i'm fine thanks, how bout urself?
after last night and then getting the quote back to fix my car.... not to well....
also i just need to set things right.... john stop calling me..... i really don't care if all the boys and girls on sau are laughing at me.... they don't even no me... you don't even no me... you say you do, but you really don't...
all's been confirmed
:laugh:
It's been confirmed has it... You really don't no me than...
Just a little information for all you....
really John is it any of your business or sau's business if i am dating Eddie....
NO.... It Mine!!!!!!!!! and if you want to treat someone with disrespected just because of who they are dating, then that is wrong..
you all need help....
This is the first i have heard about this...
Dont tar me with the same brush...
Can someone fill me in with whats going on around here via PM plz...
You should keep your beef with John, with John...
The rest of SAU dont really care...
yay my intercooler just arrived, deleivery guy stepped in dog shit hahahahahahaha..
Now, does any one know a good place to go on the northside for install? and how much it wil cost?
There is more to fitting an intercooler than just cutting a bumper...
There is quite a bit too it if you are doing it properly and to DOT standards...
It took me and my father inlaw about 5 hours to fit mine, the reason it took so long was we had to weld tabs onto the bumper support and front bar needed to be cut about 10 times before we got a good fit...
Its not a rush job...
ok i will reprase, anyone know a shop north side that will do install. i need number today so i can book it in for next week :D
and please dont say your place col :P
in my opinion... its only worth doing if you know how to do it without any hesitations or needing to ring or ask anyone questions about something.
otherwise, if u want to do it yourself, i'd have someone who knew what they were doin with you to guide you through it.
yeah, i know, but i got no idea when it comes to it, so it would take me like 5 days lol, and i would probably need a new bumper by the end of it, after wrecking it trying to take it off or back on
Not to mention you need to cut a few 3" holes and pull the front end of the car apart...
I would rate is as a 3 start dificulity out of 5...
Fitting GT30 turbos is a 4 star... :D
Changing the oil is a half a start... :P
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
