Since i arrive on the 4th my proposal was for either hoggies or lone star, for a long over due good stek
Hoggies and lone star are OK steak
Would you rather we orgainised you GOOOOOOOOOOOOOOOOOOD steak?
Well suggest away?
I only said those cause i know them, but if you have somewhere better in mind?
or we could all wait till like the 10th or 11th, of december (hopefully not to close to christmas) and get on board our boat, go deep sea fishing, and have steaks out there in fully air con comfort :D
who wants to go :D. or should i repost in january after christmans
best steak i ever had was up at the Australia Woolshed years ago.
hrmmm! i say we prep a steak cruise to the woolshed :D
perhaps we could have a week of steak tasting, 7 days or 7 different steaks at 7 different places..
whose in
Sounds like fun, remind me closer to the date
Well suggest away?
Morrison
Norman
Regatta
And the grand daddy of them all Brekky Creek
Speaking of christmas, What is everyones wishes for christmas
Working airconditioning in the R32 and a sold R33
Morrison
Norman
Regatta
Oh how could i forget Brekky Creek, I should give myself slap about the head,
Ok scrap lone star or hoggies, how about brekky creek?
OMFG!!! you people have to much spare time only gone for a dday and there like another 11 pages.....
of junk!!!!
i cant believe i read it all!!!
you all owe me 30 mins of my life back!!!
oh and Good Morning Ladies....
:D
Hey whats wrong with Hogs Breath?
I love their Prime rib.
There Prime rib and Ribs combo is awesome...
and if you have Shopper docket its 2 4 1 main meals!!!
SHOPPER DOCKET FTW!!!
:D
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
