So its true Redcliffe chicks are all mutt's?
dunno, onyl part of redcliffe i go to is the area i live (newport) and the chicks are to busy snobbing you :happy: these chciks were mainly from D Bay.. no amount of alohol i drank seemed to make them any better.
Ah k, I’ve only ever been to redcliffe dyno area haha
hahaha chilli fest is gold, anyone who doesnt think so sucks ass and can leave the forum!
Fine den!!!
*Opens Door*
Just kidding!!!
Bring on the chilli!!!
Ha ha ah i dont even know what your talking about
hahha yesterday i went and watched my friend feeding 2 inch gold fhsih to his barrumundi, nothing like watching a gold fish dissapearing instantly lol.. only remains were the scales he spat out lol
correct, however cactus jacks is weak sauce!
shame...shame...shame ? :/
hmm
is the details for next tuesday night dinner up?
yes
lmao awesome!!!
Hey Numb Nuts, Look in the events section, Tuesday 12th of december is a Nando's Buranda....
he he he
:happy:
so harsh, i like it :laugh:
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
