i was up till late discussing with a friend our engine options for it. it'll be either a 13BTT, 20BTT, 2J or a UJZ (lexus v8) cant decide. i wanna keep the weight low and balanced.
build one of these then
http://www.youtube.com/watch?v=WirkGXYdOus
i know this is a long video but watch it if u can.
http://www.youtube.com/watch?v=v8Y7v994SKk
i would own an nsx for sure they are a mad car. all aluminium body pretty much a race car for the road. ayrton senna help design and build it before he died.
not all hondas are rice, pity fags over here only make them that way.
well one of my friends from brisbane has a EG civic sedan with stripped out interior with jap spec H22a motor in it. it goes hard, purely built for racing. i mean for n/a it goes hard,and sounds tough, but al these other fags buy hondas give them a bad name, they dotn race them, they put massive wheels on them, rice the stereo's and interior and they are heavy p.o.s with single overhead cam motors in them still. that is why they get a bad name. and ppl hate them.
i just dont like the whole honda concept to be honest. just not my kinda car. i'll admit they are fast cars for what they are, but they just dont appeal to me ;)
Honda is trying to squeeze milk from a rock IMO going down the NA path...
Whats there quickest production stock car?
From memory a special edition of the NSX was doing 12.4s over the 1/4. Keeping in mind that japanese agreement thing was still in place then. They were probably a bit over it, but unlike turbos its not just a simple thing of removing a little restircter to get more boost.
That and those s2000's do the best burnouts.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
