bah way to rub it in :) infact even if we didn't have restrictions i couldn't wash the car here i live in a townhouse complex and theres really no where i could do it easily.
Makes more sense to pay mt gravatt carwash 33 bux and get a full wash wax and interior clean :huh:
yeah i reckon, we got nothing like that up here at all.
souds really good.
yeah i think because i have the r34 seats and a few other silver things (boost guage and my door sill panels are actually polished stainless steel) it came up ok
start back at work on the 8th jan.....at bundaberg on my first week back from holidays :)
yeah i didnt realise what u had done to your seats until you said, looks good. u can go visit the inlaws in bundy again lol
i start back on the 2nd.
there wont be much happening anyway but we are still opening.
ud seriously trust ur pride and joy with some mofo that wouldnt know what the difference between a synthetic and natural wax? :)
its not a proper wax just a spray on coating... they dont buff it in or anything. Its good to use between real waxing jobs.
As i said i have to use places like these (or a carlovers) as i dont have the facilities to detail the car like i used to, plus its illegal now to wash it properly :huh:
As i said i have to use places like these (or a carlovers) as i dont have the facilities to detail the car like i used to, plus its illegal now to wash it properly :)
that's a Detail Spray, which u should buff off.
depends, u only give them one go at it see what products they use etc they cant hurt it that bad.
You'd be supprised. Its extremely easy to put scratch marks in ur paint if ur not careful. You fellas should see the cars that i do :huh: (if u want ur own car done, i can arrange that)
My name is Isaac and i live in a trash can
I see ur edit, and raise u an edit :)
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
