hmm true.. but then it would look like im lying or something and he could proably sue me for legal costs or some bullshit
i remember a while ago you got assaulted at the trainstation didnt u shane? anything ever happen with that?
true true
nah got mugged on the way to the train station. filed a report, cops took photo's but couldnt do anything else caus had no way of finding out who it was that did it. (no cameras etc)
my mate just pointed out that if the guy goes to court and pleads innocent i gotta front up to court with a lawyer...
i want to see this guy get pwned big time but will be more hassle than hes worth
give me his details if you really want to sort it out, i wont have him beaten or anything, but i can get compensation out of him for you :laugh: it wont be through the legal system though
Get free legal counsel.
I got rolled once by some 20-somethings when I was a little kid (15 - what sort of lowlife gangs up 3 on 1 on a kid half his size over less then 10 bucks?) - they were too stupid to steal my mobile phone however and I walked round the corner and rang the cops... the scum who did it are now in jail, and it didnt cost me a dime, police represented me.
That being said, most of the work was done by southbank security. They are the ones who detained the scum, they built the case and all the cops did was rock up, take custody of the scum and summons everyone to court.
hmm well might as well go down to a station and have a talk to them at least... i'm sure they can answer the questions i have and what'll happen
im thinking what if i was some old man, or what if i had kids in the back or something - ppl like this clot need to be put back in there place or society is only going to get worse!
society is already at its worse dude.
it only gets worse from here onwards, never any better.
yeah but if everyone rolls over and does nothing then the ferals take over and things get a crapload worse than they are now
like i said, you want justice you have to do it yourself
i know i know, but i dont have enough info on him. Only thing i could do would be to stake out where i saw him this morning and see if he comes back.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
