nah dont think it goes up that high.. but you wont need that much strenght for the gasket job? the only time i used mine was on the head bolts and they took about 72ft/lb
mine goes upto 250ft/lb. flywheel bolts are 110ft/lb but the main crank bolt is 340ft/lb
oh poor shane lol
cheer up mate! At least it wasn't something much much worse!
yeah i was originally thinking it was a rebuild job, i couldnt work i was dredding it that much :laugh:
yeah mines a 250 one aswell..
by the time you get to 340 thats pretty tight.. for the cressidas crank pulley i used a teensy bit of loctite and this bad boy (borrowed from a mechanic) :
no idea what the tool is called but it worked good
you put a socket on one end and bash the shit out of the other
hey ian.. just don't listen to what shane says.
:P
haha that's dan's, i used it on the last 33 i did a clutch in (the crank bolt came loose when i was undoing the flywheel bolts :laugh:)
Okay, prehaps i should rephase my question...
ATM I change gears at about 7000 RPM if im driving spirited, is this too high for a RB26?
It doesnt redline till 7.5. If I keep reving the car out this high will I do dammage or can the RB26 take thoes sorts of RPM comfortably?
3-4k ian (no smart ass comments any1, i have driven a gtr a fair few times recently)
oh wow.. really?
you must be an expert then!!!
lol... sorry.. we have a member that says that kind of stuff all the time! he's had his car off the road for 8months and not a thing done.. he reckons he's an expert! He drives me insane.
lol shane do you like tomato or bbq sauce with your pwning :laughing-smiley-014:
oh wow.. really?
i'm not an expert, but im far from stupid aswell. plus im not afraid to ask questions to double check things!
soo wats wrong with him then? or is he just too lazy to do nything to it? :laugh:
How often do you drive 'spirited' as you say??
Changing gears at 7000 rpm wouldn't be overly good for any engine on a regular basis IMO
lol hi5
i dunno.. he's just a f**kwit. that's what's wrong with him
but seriously.. no one knows why it's taking so long, he's buying another car now too so it's not like he's out of money.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
