we got our phone bill yesterday at work. the boss is not happy :( someone has been using the company phones to make excessively long calls to mobiles. one call cost us $40 :) staff are getting an ass kicking today :)
shane... how we goin to get ur car out to the photoshoot?
or can we leave urs till next yr?
yeah stuff it, leave it until next year, that way its got a better chance of being finished and not in pieces :)
Its alive!!!
my cars going. Oh and I got some iridiums now as well....
It was a dodgy wiring job. Someone had re-wired the top AFM for some reason... and it didnt work so well.
Bed time....
so we werent going crazy then with those intake pipes...what did they end up charging you? pm if u want
and john, bite urs :)
Ian what's up with your car? I saw in the spotted thread something about a truck? :):(
Its alive!!!
Bed time....
LOLZ, never mind :( Good to hear it's going :)
Its a looooooooooong story.....
Me and shane did some work on it which lead to a boost leak, which lead to me pulling it appart and apparently disturbing the AFM re-wire from hell which lead to me scratching my ass a few times trying to figure out what was wrong, along with missing out on driving on my own damn cruise, which then lead to a RACQ tow to the mechanics who eventually fixed it. Oh then when I drove away it still had a boost leak... Took it back, turns out the whole time there was one dodgy clamp that had had it causing the boost leaks, which lead to the wiring trouble etc....
Man im overtired atm, I should re-write that in a readable format but feeeeeeeeeh
goodnight all...
Heheheheeh "Truck" + Ian's GTR = loser mobile!!!
My car might not be a GTR, but it works!!!
Just jokes Ian, don't blow a gasket or something! (And I didn't mention Steph at all!!)
want a punch in the face :)
Haha dave, things have changed since you last saw my GTR up a mountain....
But im not one to tempt fate and dont want to get into any death runs over nebo over a grudge, so ill come out right now and say your probobly quicker then me over a mountain.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
