Well i cant say my day was very hard Troy as i spent half the day going up to Nambour to get Chris's slotted brakes to fit this weekend...
Boy o boy can the guys up there talk, i was there for like an hour chatting about motorsport...
yeah I have been at dans and fitted my water pump and oil pump. Seated the cam saddles and helped him sand the bonnet of his car :) so overall pretty cruisy day just for got to have lunch but.
well, i'm finished for the day kids. i will cya all tomorroww, if the server doesnt die on us again.
let me know (sms) if you decide on what you want to do troy.
I have been sitting at Allstar since 8.15am. Seems what we thought was my throw-out bearing wasn't!!!
Still waiting but it justs needs the boss to test drive it and I should be out of here!!
Wouldn't mind a movie tonight?? 9pm session at Garden City?? Or Indooroopilly?? What started today?? CBF looking on Richo's computer as it is ssslllloooowwwwwww......
Arhhh nice, well im waiting on 3x 130mm hose clamps and a fitting for the right hand tappet cover before i can start my car and see if it goes... :(
It probablly will pi$$ oil and water from everywhere...
I also need to replace my oil feed line as the $150 braided and speedflow fitted one i have is not good enough aparentlly... I now need to spend $150 more to get a silver soldered one...
how r u feeling dave???
Yeah any better this arvo mate...
Even though I have done nothing today, I feel wasted. Seeing doctor tomorrow morning and maybe get more time off. May need help moving some stuff on the weekend if ANY of my plans come together. Probably not..
And it was the spigot bush in the end, after we tried everything else first!!
Would like to get out of the house tonight though. Movie would be good!!
Apparently my car is ready so have something organised by the time I get home!!
sigh sigh sigh I think my clutch is starting to slip...
Im gona need a replacement, and I want a twin plate. There about $1000, no?
Lolz a TS2BD Like mine is about $2400
Dan may have some cheaper
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
