I NEED CLUTCH!
I think. I dunno. Its hard to tell if its slipping. I could of sworn it was last night, but then when I tested it it griped.
Car feels slow tho.... But when I say take off from the lights and it doesnt feel like its pulling like it should, I look behind and the trafic is way ages back and i havent sped...
Could it be the spiget bearing?
I NEED CLUTCH!
Mine is the same thing, IT started like that, then after a while I would hit full boost and the car would actually go slower lol...hence the reason it is getting rebuilt on Monday :D
well dave you want to see night at the musem as it looks kinda funny.
Ian talk to Dan and he maybe able to help you out (he is back at work on mon). And no i personally don't think it is the spiget bush
lol yes I think its a bit excessive thinking a twin plate, just a button clutch should do the job well, but then again I am no expert.
hey andy you and anna up for a movie tonight and garden city?
lol yes I think its a bit excessive thinking a twin plate just a button clutch but then again I am no expert.
Not a 9:00 session I need to sleep
Plus we have already seen every thing lol
well I am trying to keep it looking clean :D its all been done with spray can VHT paint and must admit my skills are getting better.
waiting on my balancer and some other stuff to be painted and then full steam ahead :)
ANNA SMELLS
NOT THE BEST NOW :kiss:
ANNA SMELLS
NOT THE BEST NOW
ANNA SMELLS
NOT THE BEST NOW
ANNA SMELLS
NOT THE BEST NOW
ANNA SMELLS
NOT THE BEST NOW :no:
damm keys
dont want to let me whore it anymore then i can :(
fat fingers?
going to check out a car (if you know what i mean)
does it have legs?
i'm up for a movie or something like that, but would have to be after 8:30. i'm meeting this guy tonight to check out this suss car. you can come if you want, and then i'm free afterwards.
what about that one with will smith in it?
yeah I have been at dans and fitted my water pump and oil pump. Seated the cam saddles and helped him sand the bonnet of his car :) so overall pretty cruisy day just for got to have lunch but.
did u get N1 pumps?
I have been sitting at Allstar since 8.15am. Seems what we thought was my throw-out bearing wasn't!!!
Still waiting but it justs needs the boss to test drive it and I should be out of here!!
Wouldn't mind a movie tonight?? 9pm session at Garden City?? Or Indooroopilly?? What started today?? CBF looking on Richo's computer as it is ssslllloooowwwwwww......
one of ur main problems is that haltech u run dave :ninja:
Ooh so what was it? Spigot bush? Bearing on the input shaft? Small animal inside the bellhousing? :D
or maybe a bit of rope :)
sigh sigh sigh I think my clutch is starting to slip...
Im gona need a replacement, and I want a twin plate. There about $1000, no?
TO4GTR (aka dave) has an OS twin if u want a twin, but twins are overkill.....*moves to andy's post*
Lolz a TS2BD Like mine is about $2400
Dan may have some cheaper
sif u paid retail for it though :P
agreed troy...old GTR plus stock clutch = all parts of the clutch rooted but mostly the pressure plate
*Cue Jim Berry plug from Shane in 3.......2......1...*
well u cant beat a tried and tested clutch now can you, and at half the price of a stinkin twin, plus they dont rattle like a mofo
uve only got the twin to look tough, we all know it :D
button noooooooooo dirty dirty things, hate them with a passion :P (id have a twin/tripple/quad over a button lol)
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
