bahahahaha my boss wanted to "net meet" with me, so I had to shut down all windows that could get me in trouble :(
"man you will not believe who's balls are on my shoulder.... Dave Chapells!!! And their so smooth and shiny!!!"
bahahahahaha
*wees*
u been here all day just to try and get on that list?
dude, try bein on that list 3 days straight and at the top
i did it :(
some people work for a living... i just have realistic goals in life and am happy with them..
STOP JUDGING ME!
*goes off and cuts self
bahahahaha my boss wanted to "net meet" with me, so I had to shut down all windows that could get me in trouble :)
bahahahahaha
*wees*
is that what ur boss said? i'm a bit confused? :(
bahahahahaha
*wees*
ha ha ha he's a funny man...
you should watch all the episodes of the dave chappel show on you tube, its a crack up...
is that what ur boss said? i'm a bit confused? :)
yeah that's what my boss said... :(
LOL as if!! i'd clearly be rich from law suits if I worked somewhere like that!!!!!!!!
ha ha ha the smooth thing came out wrong!
Edited by LIL34
their balls or their pick up lines???
i have 2 of his stand up shows at home...
they are so funny....
I love it when he's like "when you get pulled over by the cops talk in a crazy voice, they can't book you for that! Talk like a bad guy from the 40's"
policeman: "son did u know why i pulled you over?"
Chapelle: "nyyyaaaaaaaaar it's cos i'm black seeeeeeeeee!"
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
