Everyone go order a calendar -
http://www.skylinesaustralia.com/forums/in...howtopic=154015
i run this at a lost, i aint going to be happy.
specially after the amount of hours i've spent doing this project.
why dont you wait until you have at least 75% of the calenders paid for before you order them??? Otherwise its a big risk imo.
bit of an understatement :O i believe farking hot would best describe that. very unique as well. thats in the states isnt it
yea its in the states. Its hot but yea, its one of the only hot ones i can find and I reckon it would be expensive to get someone in Aus to fabricate a kit..everything i want is too expensive and is200 with a 1/2j, a 3000gt with nice kit and minor mods...everythings too expensive arghhhh!!!! I guess its the price of wanting something sorta unique!
thats pretty much what im doin.
placin orders now while im still doin the artwork will make things flow alot better.
and once you see the layout of this calendar, you'd be gobsmacked and wont be able to wait until next years one.
this calendar is pretty much designed to make heads turn :O
are you going to post some pics of what its going to look like?
:O
ahhh she's back!!! *runs and hides*
hi anna ;)
i know what you mean. the kit i want for my next car is going to cost me 5k just to order it from japan, plus an extra 2k to fit it and paint it (thats through my friend as well, 1k for paint job) then again, it is a wide body
so which one of you girlies are coming to night???
you know you arranged it so you need to count the numbers and make the booking still mike....
i'm not going to get a chance lee :O i've got to prepare notes on the performance of my branch and shit. i only have 1hr to do that in. then i gotta drive out to hendra to go to the meeting ;) its bullshit, it really is :O
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
