Grrrr stupid temp here won't shut up!
anna, today is your chance to get back at her! crap on her desk and piss in her drawer! do it!
if you dont know what it is you dont deserve them..... :laugh:
meh, not worth having then :laugh:
although i am still curious :)
this is the route we are going on sunday:
I suggest cut across town, up payneham rd, montecute rd, corkscrew rd, right up gorge rd and back down via north east road back to town and then the airport.
anyone know adelaide at all?
What does the job at your work entail, mikey, and is it full time / part time / casual?
ummm, customer service mostly. obviously there are things to be cleaned and someone has to go across the road to get my lunch. full time on a rotating roster
like i give a Mcshit..... dont make me kick you in the McNuggets :laugh:
lmao gold lee, just gold
hrmmm... I think the WP jobs sound more enticing.
my favourite anime =
mmmm, ninja scroll, such classic anime.
i just ordered $200 worth today. also noticed fullmetal alchemist movie and Fullmetal panic: the second raid come out on thursday! :laugh: i cant wait.
I really like the Ninja Scroll movie... Have you seen a show called Wolf's Rain?
no, i had a look at it a while ago, but had no more money from a big anime spree :laugh: $900 in one day, no kidding. i'm well and truly addicted.
have you seen the series for Ninja Scroll?
Ninja scroll Hai fiiiive
Go the guy with the wasps living in his back!
yeah he's effing gross...
I still think the freakiest guy is the one with the flame in his chest and is see through that rapes that chick... he's so creepy!!
And the chick that sewed all extra arms on her and she's like a crazy corpse spider!!!
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
