due mine is bigger!!! this long <------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------>
OH yeah :(
Hi5 :sorcerer:
I doubt it is drawn to the same scale as mine
Plus mine is older
How many magazines has your ewang been in?
How much power at the eballs did it make?
How many ewangs have you owned?
well lets see. Highest power figure was a 1969 ht 350 monaro, You probably dont remember those. It only made 510 horsepower tho. guess it wouldnt beat your undercoated tojo.
my cars not in undercoat, your memory gone already? And no that overweight whale probably wouldn't have beaten my 33, and it definately wouldn't have beaten josh's silvia.
I doubt it would have too, they were heavy cars. But shit i had fun in it.
Plus mine is older
i lol so hard i peed a little..
dam you Andy :P
well i'm off home thanks for the entertainemnt (sp) but your all still too weak....
the cars i've owned.....
Toyota Corrola
Toyota celica
Toyota Supra
Nissan blue bird sss
Nissan pulsa n15
Nisan Silvia 13
Nissan Silvia 14a
Nissan Silvia 15
Skyline 32 GTS4
Skyline 32 GTR
Skyline 33 GTS4
5 Skylines 33 GTR's
Skyline 34 GTR NUR sII
Mines 34 GTR
Lambo Mercelargo (sp)
Porcha Cynen (sp) S Turbo
Astin Martin DB9
the list goes on......
heaps of FWD and Tarago's in between...
Beat That :(
and to this date....blown motors fixed and in the car running.....0 :P
adding to that remark, blown motor tally may just grow in the near future :happy:
dam you Andy :dry:
Toyota Corrola
Toyota celica
Toyota Supra
Nissan pulsa n15
Nisan Silvia 13
Nissan Silvia 14a
Nissan Silvia 15
Skyline 32 GTS4
Skyline 32 GTR
Skyline 33 GTS4
5 Skylines 33 GTR's
Mines 34 GTR
Astin Martin DB9
Beat That :laugh:
dreams dont count :laugh:
Beat That
yo lee/dom
the car yard i used to work at used to let me do some wholesale on the side and ive technically owned between 100-200 cars.
some of the highlights include a 1965 XP Falcon Sedan w/66000klm on it, a 05 F250 XLT 7.3l turbo diesel V8 and a thyphoon with 330kw at the wheels.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
