evenin you phat whorebags!!
laptop died...quote to fix $2500!!! just got a new one, this windows vista sucks ass... took forever to get my wireless going lol . still i'm happy i did it myself, gotta ring up the it geek people i had booked to come out tomorrow and tell them they're not needed :)
also, teh zac needs to decide by tomorrow if he is moving to buderim or rockhampton..
rocky would be way cheaper to live and i will get a juicy promotion out of it if i go for a 12month contract up there... but buderim has a better climate and is closer to brisvagas :) but will cost more to live there and the lab probably isn't as fun to work in as rocky's one :)
yeah true...
and col i should have spoke to you about my laptop! i went to harvey norman at everton park (i think) on south pine road (also i think...) and first they sold me a computer that had already been opened and resealed- got it home and had no power supply and the laptop was already in standby..then swapped it for a new one, got it home and the surge protector blew up within 30min of using it lol
yeah true...
thats pretty bad..specs of your new lappy??
yeah true...
Yeah you should have given me a buzz...
I could have hooked you up...
Everton Park is one of my stores too...
hehe.. poor matt had to slave away for 2 hours in poor lighting to get it installed, but it is up and running :) hope you havent drank too many more of those beers already or this thread is likely to get crazy pretty fast. pm me your msn if u like :)
thanks again
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
