:laugh: what's happened???
Andy was on his way to Gatton in the 33, and as he accelerated he noticed there was nothing. It had died and now won't re start. Not sure what's going on but there is ZERO OIL in it :P :P
Currently waiting for RACQ to tow him home so we can take a closer look. :O
Andy was on his way to Gatton in the 33, and as he accelerated he noticed there was nothing. It had died and now won't re start. Not sure what's going on but there is ZERO OIL in it :laugh::P
Currently waiting for RACQ to tow him home so we can take a closer look. :(
:P:O omg..has he said where it looks like its escaping from?
this is ghey :(
awwwwwww that's poo hun! :(
Hope it's not anything too bad or spensive :laugh:
:P :P omg..has he said where it looks like its escaping from?
this is ghey :O
that's the thing... it doesn't seem to be escaping from anywhere! It's been parked in the visitors park all week and there are no oil marks anywhere. It's just gone! Vanished into thin air.
Yeh mega poo. He took the 33 to Gatton today cos the 32 is currently in the garage with bits off it (we were doing the oil cooler relocation thingy on teh weekend and needed extra parts, so it's still not back together yet). When he called to say the car was broken down I nearly flipped!
that's weird as...i put ~5ltrs of motul turbolite in it and its goone! doubt its rings caus ud see/smell it.
Morning Ladies...
that sucks to hear Anna, i say Blame Shane LOL!!
Noel thats prolly typical of them why dont you just go striaght to the Alarm company, it'll prolly be cheaper and they will have stock.... Ask John, he saved like $100 going straight to mongoose and getting them to install it. Have you talked to Chris Rodgers?
Morning Ladies...
haha hi sau...
wat did u stuff up now shaney poo?
eat a d!ck you 2 :laugh:
Oh dear :P
what what??
Shane didn't do anything wrong. There's something iffy with the engine. Heheh. Gine.
phew! thats a massive relief! lol
but what can the problem be, dan was there when the engine was compression tested :laugh:
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
