We had tried that, just directed to the HR manager, ended up sending resumes and nothing ever came of it
which places did u try?
i could find out contact details if ur seriously keen.
Mum sold it :domokun: I am still dirty about it
The bulldozer lives at my brother inlaws 7000ha property near biloeila....7000ha and a D6 is a whole lot of havoc lol
this sounds like a fly in fly out weekend
The havoc alone could be worth it!
I bet they are, whats one of those puppies put out, turbos are rather decent :domokun:
I think a d6 is only 180hp...but like a bazillion nm of torque they only rev to about 3000rpm and thier stroke is measured in M not mm ha ha
what do u want with 'truck' turbo's josh? :domokun:
Nothing, honest!
Those turbos I told you about were off something cat… I think it was a D6, but it could have been another dozer. Very close to T88 wheel size, be interesting to see just how they perform from a budget build point of view.
Nothing, honest!
I would say Our cars wouldn't be able to hit the blades hard enough to make them spin! They are designed for masses of low velocity air
You should have seen the compressors on the Train engines when I worked at QR! Those engines put out 2500+hp some we dynoed made as much as 4000hp and 8000nm!
Fark!!!@ Crazy numbers.
I thought much the same re: the blades, however I friend made something like 320rwhp on his rb20 with a truck turbo (well size bit bigger then hks old school t04 size), cooler, fuel and mines ecu ect. Was laggy as, and not a streetable or usable 320rwhp.
I can get the units for... lets say cheap. Cheap enough to have a turbo shop to put new wheels in, duno wether its worth it cost wise, never done the RnD.
Edited by Nismo_Boy
Yeah you can get good numbers running a 32L V12 with a super charger the size of your torso for each cylinder bank!
Hmm that could be interesting
shoe horn one into an R32 drag car?
From memory I think it is bigger than R32 ha ha I remember the pistons being bigger than my head and each cylinder has the same capacity as an RB26!
Lets just put a wheel on each corner of the block and sit in the valley between the heads, would be funny to see an engine with wheels do a 10 second pass crossing the line at 3200 rpm
They must be some ooooorful big pistons. :domokun:
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
