Whoretown - Now Interest Free
Squizz
ha ha ha ha she's so effing lame.. don't worry lil miss, i'm starting fights for you :nyaanyaa:
LMFAO@ "joke hitler" from that video bahahahaha
p.s. they should all die in a fire....
link
yer I hope flesh eating bacteria crawls into her womb and devours her unborn fetus ..
And then she 'accidentally' gets sodomised with a splintery baseball bat covered in razorwire..
my kind of situation...nothing like tearing someone apart....:S
ooookkkk....medication is your friend.
bahahahahahaha if you say one more word i'm gonna blow my brains out
I HAVE A GUN! .... I do... I have a gun....
BOOM
wouldnt be much to see if u did blow ur brains out :P
:nyaanyaa:
Pics of you blowing?
3rd'd
Anna I f**king tell you what I'm gunna f**king start slitting f**king throats soon .. Those f**king hepatitis c ridden f**king crack whore moles .. I hope her child grows wooden legs and gets caught in a f**king bushfire or a f**king termites nest .. f**king diseased ridden whore :ninja::P:P
GRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!!
boostloosing crusing?
lol nah these girls deserve worse than what Kitas is saying.. LOL
don't worry keets... she's fat, preglet, and ugly.... we should feel sorry for her... which I do....
Does anyone else know who these people are?
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
