:ninja:
get her to send me pics!
LOL
is it lacey? see thru? leather?
bahahahaha
she's sexeh no matter what :P :P kaz
Damn straight :wave: The top is partially see through and a bit adventurous. Hot without giving too much away :)
I'd like to get some pics for myself >_<
I try moite
wana fit in aye
fully sick...
Looks like i have been f**ked over. I have been in negotiation with a dude for his dish wheels and he has vanished from the face of the earth. Oh well, shit happens
Dont worry he will come back in two weeks and ask if you still want them when you've gone and spent the money on something else!
get her to remove the bans, and then things will settle down.
or this may just keep on happening, and ban's wont stop us, there are ways to overcome bans if we feel the need :wave:
I know this is none of my business? but why do you care if you're been banned or whatever off boostcruising?
Everyone takes the internet so seriously.. >_<
Tell me more about these 10hp ecu mod thing u spoke of on gsx the other day
link?
It's basically a PowerFC for the bike. I can't remember exact numbers but IIRC the exhaust gives you around 7 or 8 hp at the top end and a fair whack in the middle, and the PC3 lets you tune to suit the bike (as with a car, each engine is different) and the mods. Most people I've spoken to are extremely happy with the results.
Their website: http://www.powercommander.com
This one's a bit out of date but gives you a good idea: http://www.mcnews.com.au/Product_Advertori...PC_USB_News.htm
You're not actually banned, only mod reviewed.
Your account is basically active still, you can still view the site just like any other member, however when you post, it must be reviewed/approved by a moderator before it is allowed to be shown to general viewers.
And yes, there's always ways to overcome bans, I know, I am a computer geek myself >_<
He shouldnt but he does, cause he has a lackof work and he needs to stir people up....hence boost cruising....he could get another user name if he wants....but no your right....CAREFACTOR 0...
i wove you shaneypoo
Chance's of me dying on a 600 with said mods?
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
