found pics of the old 33 on my phone....i'm so sad :laugh:
My list:
HKS 3037S Turbo
HKS External Wastegate
HKS Stainless Steel Manifold
HKS Triple Plate Clutch
HKS 256' Cams
TRUST Greddy Plenumn
HKS 6x740cc Injectors
Uknown intank fuel pump (large)
Custom Fuel Rail
80mm throttle body
HKS F-CON V Fuel & Ignition ECU
Custom G/force 600x300x100mm Intercooler
HKS Airpod on custom 100mm piping with airflow meter removed
Line Locker & Controller
TRUST Profec A Boost Controller
TRUST Turbo Timer
TECHTOM IIC460 Drag Launch Controller
TRUST 60mm electronic Boost & Exhaust Temp. Warning Guages
Autometer Sport Comp Monster Tacho & Shift Light
Apexi N1 80mm Exhaust
HKS Front Pipe (Turbo to Cat)
Custom Stainless Dump Pipe
Cusco Oil Catch Can
Cusco 1.5way Locking LSD
Veilside Shift Knob
Recaro Recliner Seat with Sabelt Harness
Potenza Suspension
Nismo 400R front bar (needs repair)
Different Skirts, Rear Bar and Drag Style rear wing
17x8 and 17x9" White 5 Spoke Wheels
Slotted Front Brake Rotors and Aftermarket Brake Pads
Rebuilt Gearbox with brand new gear set.
My list:
HKS 3037S Turbo
HKS 256' Cams
Huge Fuel Pump
Custom Fuel Rail
80mm throttle body
TRUST Turbo Timer
Cusco Oil Catch Can
Veilside Shift Knob
Potenza Suspension
Holy shit thats alot of stuff.
Edited by subzeroR33
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
